Bobcat Skidsteer Forums
610 drive pulley removal
Reply to thread
Message
<blockquote data-quote="6brnorma" data-source="post: 45173" data-attributes="member: 5914"><p>I asked where you were located thinking possibly I'd know someone who might help you with parts or advice, unfortunately I don't in your area. You are probably right about the damage. It is likely that the broken ring was due to excessive pressure from the variable speed valve. Should you decide to make the repairs, be sure to check those pressures. I've done it but make no claims of expertise in that area. The last time I bought the entire sheave assembly new, if I recall correctly, it was about $600.00 and was still available from bobcat .... that was a couple of years ago. I certainly wouldn't "can" the machine due to this.....especially since you got it for a very reasonable price and I'd bet you've got many hundreds more worth of work for it.</p></blockquote><p></p>
[QUOTE="6brnorma, post: 45173, member: 5914"] I asked where you were located thinking possibly I'd know someone who might help you with parts or advice, unfortunately I don't in your area. You are probably right about the damage. It is likely that the broken ring was due to excessive pressure from the variable speed valve. Should you decide to make the repairs, be sure to check those pressures. I've done it but make no claims of expertise in that area. The last time I bought the entire sheave assembly new, if I recall correctly, it was about $600.00 and was still available from bobcat .... that was a couple of years ago. I certainly wouldn't "can" the machine due to this.....especially since you got it for a very reasonable price and I'd bet you've got many hundreds more worth of work for it. [/QUOTE]
Verification
Post reply
