Aug 16, 2014 #2 F farmshop Well-known member Joined Mar 27, 2014 Messages 698 Anyone change rear axle seals on a s590? Ours has both back ones leaking. Have done fronts and old f series 763 just not on this one
Aug 18, 2014 #3 T Tazza Moderator Staff member Joined Dec 7, 2004 Messages 16,829 Isn't it the same deal as the 763? loosen the hub bolt, get the hub off and remove/replace seal? I assume it has the same axle setup?
Aug 20, 2014 #4 OP OP F farmshop Well-known member Joined Mar 27, 2014 Messages 698 Tazza said: Isn't it the same deal as the 763? loosen the hub bolt, get the hub off and remove/replace seal? I assume it has the same axle setup? Click to expand... You are correct tazza I was overthinking things. Picked up seals now just have to do it
