5625sx slow lift and tilt
alexp
Both lift and tilt are slow. Does speed up with rpm but still slow. Will not lift the bucket at idle speed. So far I have tried to clean the strainer, replace the filter. No metal and oil is clear. Check the aux pedal was not sticking, Made sure the linkage was moving full travel. Does anyone know the correct pressure and at witch ports. Thanks in advance.
Firefighter
check the pressure at the auxiliaries, im guessing between 2500 & 3000 Psi would be normal
Could be the relief valve faulty i think that model has an adjustable valve, with orings inside that can fail n
cause low pressure, if the relief valve checks out then its the pump
