50" bucket on a 463 / S70
SkidRoe
My dealer accidentally ordered an S70 in with a 50" bucket. I was looking for a bigger bucket for handling snow, and ended up buying it off him. Has anybody used one of these before on a small machine in something other than snow? How does the machine handle it?
Your 463 has a Rated Operating Capacity (ROC) of 700 pounds.
The 50" bucket weighs 202 pounds. This only leaves you 498 pounds for material.
The 50" bucket has a struck capacity of 8.5 cubic feet. If you level fill the bucket, the material must weigh 58.6 pounds per cubic foot or less to keep you within the ROC.
Here is a list of common materials and their weight per cubic foot. Dry Loose Dirt is approx 76 lbs per cubic foot. A full bucket will make your machine very nose heavy. You may end up only being able to take partial buckets on many common materials.
You may also find you don't have enough traction or machine weight to get 50 inches of cutting edge to penetrate into the soil.
Hope it works out for you.
MaterialPounds Per Cubic Foot
Copper Ore
262
Slag, Iron
172
Quartz, ground
165
Gypsum
159
Limestone
155
Sandstone
143
Sand, wet
126
Earth, wet packed
115
Clay, damp
110
Lye
106
Cement, Portland
94
Shale
92
Gravel
90
Sand, dry
90
Stone, broken
90
Concrete
86
Earth, dry loose
76
Potash
68
Clay, dry excavated
63
MAP,DAP
60
Paper
58
Bone Meal
57
Sulphur
55
Rubber, scrap
50
Beans
48
Potatoes
48
Soybeans
48
Wheat
48
Coffee Beans
45
Corn
45
Flax Seed
45
Urea
45
Malt, dry
45
Rice
44
Sugar Beets
40
Coal
40
Snow, wet
40
Barley
39
Ice
37
Lime
36
Ashes
35
Charcoal, Oak
35
Salt
35
Coke
32
Oats
26
Cottonseed, Dry
25
Sunflowers
24
Hay (Baled)
20
Peanuts, shelled
18
Wood, chips
18
Wood, sawdust
15
Material
Copper Ore
262
Slag, Iron
172
Quartz, ground
165
Gypsum
159
Limestone
155
Sandstone
143
Sand, wet
126
Earth, wet packed
115
Clay, damp
110
Lye
106
Cement, Portland
94
Shale
92
Gravel
90
Sand, dry
90
Stone, broken
90
Concrete
86
Earth, dry loose
76
Potash
68
Clay, dry excavated
63
MAP,DAP
60
Paper
58
Bone Meal
57
Sulphur
55
Rubber, scrap
50
Beans
48
Potatoes
48
Soybeans
48
Wheat
48
Coffee Beans
45
Corn
45
Flax Seed
45
Urea
45
Malt, dry
45
Rice
44
Sugar Beets
40
Coal
40
Snow, wet
40
Barley
39
Ice
37
Lime
36
Ashes
35
Charcoal, Oak
35
Salt
35
Coke
32
Oats
26
Cottonseed, Dry
25
Sunflowers
24
Hay (Baled)
20
Peanuts, shelled
18
Wood, chips
18
Wood, sawdust
15
Good info. Looks like it will work good for snow!! I think it will be fine for what I am going to use it for. I am keeping my 42" bucket, so I will always have it for digging. Thanks!
If you're hauling wood(from Hearth.com):
Thoroughly air-dried (10-12%) or kiln dried domestic hardwoods (6-8%) weigh from 30 lbs (cottonwood) to 52 lbs (hickory) per cubic foot.
Soft (Silver & Red Maple) 33-35,Black Walnut 38-40,Black Cherry 38, Red Oak & White Ash are around 40-42,Hard Maple 44,White Oak 47.
"I searched the internet and found wide variations, with claims that green oak runs 70 lbs per cubic foot."Anything weighing 70 lbs/cubic foot will sink to the bottom of the pond.
It would be difficult to get a solid 8.5 cf of wood in the bucket, unless you sawed boards specifically to fit, LOL.
I have already fit a 200 lb counter weight to the machine, so I am not worried about lifting capacity - it will lift it. What I am thinking about now is fitting bolt-on digging teeth to the 42" bucket, as I will now have the 50" that I can back-drag and grade with.
New bucket arrived today!! Does not look too big at all. And it should not take much to make it fit either. I need to pick up some 1.5" x 0.25" flat bar to make a couple of new interface plates for the old style mini-bobtach.
Touche'. But just imagine, you're deep in the woods driving your 463 and then all of a sudden it appears. 48' boards stacked in 50" bucket sized piles as far as the eye can see. You'll be prepared to haul it all off!
ROFLMAO!!!!
ROFLMAO!!!!
Okay, so here is what I started with, with a couple of cuts to make the bucket sit on my bobtach for marking out the new attachment bars:
And here it is after a couple of hours of cutting and welding, and some paint:
I ran the side plates and gussets up through the top bar to make it easier to weld:
It worked out really well. I was afraid that the side flanges were going to hit the boom arms (and1 would have to cut them off), but they sit about 3/4" outside the boom, so no problem. You could easily convert it back to fit the new styel mini bobtach, if needed, just a bit of cutting and grinding.
Answered my own question: Put the bucket to work today in some topsoil. The old 440b handles it no problem, even with the bucket heaped. I think the counter weights helped a bit...
Very nice conversion SR. Its so nice you are actually going to motivate me to start using my mig welder again.
Here is an update on the 50" bucket: It was drilled for a bolt on cutting edge or teeth, so I bought a set of 7 bolt-on teeth for it. I finally got to put it to work yesterday, digging a road bed for a driveway and a garage. What a difference!! I was figuring that I may have to drop one of the counterweights to get it to penetrate the ground - Nope!! I actually had to work hard to keep it from going too deep. This thing is like a miniature bulldozer!! Found 4 buried tree stumps and a ton of roots during the excavation, ripped them out no problem. Most of the ground was pretty dry and packed down from vehicle traffic, but it only slowed digging slightly. Extremely pleased with the performance.
Teeth sure do make a difference, especially in compacted soil.
It's always good to hear when things work out better than expected.
