4610 engine swap
jhan873
Has anyone out there swapped an engine in a 4610? If so what did you use? I was thinking of putting a 2203 kubota in it and wondered if it would fit and what all i would have to change. thanks
I am sure it could be done The V2203 DI was used in the 4625. You could use the drive coupler and adapter housing from a 4625 too. I think the tandem pump shaft is the same size between the 4610 and 4625. In the long run you maybe better off trading off the 4610 and get a 4625. If you want to put a V2203 in the 4610 go for it. Maybe a little work to make it all work but can be done.
Hello everyone Obsolete here, you all are a great group and thanks in advance you gotta get experience from somewhere right? so here goes 1974 Bobcat m 610 oem engine was a VH4D swapping with a W4 1770 wisconsin appears all to be the same just has a 3rd bearing dimensions are the same other than 35hp how do or what do I need to make Hydraulic pump operate it appears a LOVEJOY Coupler is used and it is driven off of distrubor wher can I get such parts and has anyone done this before appears engine is a 1999 and distributor is monted up top...... any advice would be great thanks in advance Obsolete!!!!!
Please start a new thread in the Bobcat section. When its in another area, not many people will see it.
