Thanks I will check that , I did fill up the tank though ,is there a screen on the intake Line in the tank MikeCheck the fuel line inside your fuel tank, it may have broken off. Remove the fuel gauge / cap on the right side and have an assistant shine a flash light in while you look in through the fuel filler cap on the left. You should be able to see if the the siphon tube is still intact or not. HTH.
Yes, there is a brass screen on the end of the line. When it breaks off, it's a fun thing to fish out.Thanks I will check that , I did fill up the tank though ,is there a screen on the intake Line in the tank Mike
Thanks for all your help It was a crack in the fuel line just below pick up elbow on the top of the tank And there was a brass screened check valve on the end of the pick up line Replaced that section Had a fight of a time getting the dry lines re purged with diesel .. Works great again. MikeYes, there is a brass screen on the end of the line. When it breaks off, it's a fun thing to fish out.
Cool! Good to hear that fixed it.Thanks for all your help It was a crack in the fuel line just below pick up elbow on the top of the tank And there was a brass screened check valve on the end of the pick up line Replaced that section Had a fight of a time getting the dry lines re purged with diesel .. Works great again. Mike
