443B axle bearing and seal part numbers
MaxW
Would anyone have part numbers for the axle seal and the bearings in a 443B? Might need a speedi-sleave as well, does anyone know the size? These are the one piece axles, not the hub, shaft and nut type. Also, what oil are people using in the chain case? Motor oil, gear oil, Hydraulic oil? Any info is appreciated, Thanks Max
Totally exhuming this from the past, but posting to give other googlers clarity. If you order the seal kit from bobcat, the kit comes with speedisleeves. I tired getting the same sleeve from napa and a few other places, and they wanted just about the same cost for just the sleeves as bobcat did for the entire kit. I am running hydraulic oil but others say to run old hydro oil or motor oil I think. I didn't want to run old stuff in here, as I intend to squeeze every last hour out of this thing.
