now it works, but the right side of the drive is noisy, and the second cylinder is leaking out. I changed the seals on both cylinders, the other works, but the other is leaking out. I once checked the seal that it is good. if the cylinder is still a little air bubbles will it leak more easily?I'll try tomorrow, still leaking cylinder and change again if the new seal is leaking. which makes the drive motors or drive pump loud? pressure is good and does not leak out? it worked earlier. leftside is good and no any noise.
