unlhuskersone
- Joined
- Aug 27, 2013
- Messages
- 3
can run the machine about 15 minutes then the buzzer starts beeping. No warning lights on the dash light up only the engine temperature needle is running in the red. Have been laser shooting temperatures on engine running around about 200 degrees and the output on the oil cooling radiator is around 175 to 180 degrees. What I have done to this point is install a new thermostat...didn't make difference so needing suggestions. I did notice the cylinders on digging arm were extremely hot to the touch when It overheats. It has the Deutz engine and is oil cooled. I have cleaned the radiators also.
