monbob440b
- Joined
- Dec 8, 2019
- Messages
- 2
Hey guys i recently bought a bobcat 440B that is in fairly good shape with a new engine, my problem is that when i start the machine , the right side lever operates 100% forward and reverse no noise ,but the left lever will not go forward until fully pressed and after a while it slowly wants to engage with pulse with bad squealing/grunging noise ,pulling it back works better almost 90%. After letting idle for 30 min and using it bit it gets better and when fully warm both lever operates like new. Only when cold the left lever will not make skid go forward just the right side works good .I do live in Canada where it is between 0 to -15 Celsius when i operate for snow removal. 1.My lift arms are jumpy when cold but goes away after 30min of usage and the skid works like new. Im going to flush hydraulic fluid and filter ,dealer said 32 but I'm leaning toward motor oil as said previous? 1.Ive tried swapping the hose to motors but they are not long enough. Should i plug the hose by motor and see if my pump will stall engine when forward/reverse? 2.I can't tell if its the hydro pump or the hydraulic motor making the noise I can try swapping hydraulic motor but it is a small job i can tackle next week Main concern is drive motor squeal thanks
