You are talking about the front part of the 4 in 1 bucket? if so, i doubt you will get another one of those bits. You may need to look for a cheap replacement if you haven't got the ability to repair the old one.only the claw is bent and wore thin
I would think a good weld or fabrication shop could easily rebuild the worn parts by welding in new steel. Bobcat would probably want like $1500 for a new one anyhow lol.You are talking about the front part of the 4 in 1 bucket? if so, i doubt you will get another one of those bits. You may need to look for a cheap replacement if you haven't got the ability to repair the old one.
I repaired one i had, i removed the floor and made a new one, it was that bad. It wasn't too much effort, just took time and materials.
I called bobcat today. Claw assembly $3900, local welder wanted $1500 to rebuild bottom without teeth. Called another bucket builder, they wanted $1500 to 1700. Called another, attachment builder, they said $700. I was looking mine over today, I would like to attempt to straighten mine and if it does not work, then have my bottom rebuilt.I would think a good weld or fabrication shop could easily rebuild the worn parts by welding in new steel. Bobcat would probably want like $1500 for a new one anyhow lol.
I'd do the same, if you can't get it right, get them to do the job for you.I called bobcat today. Claw assembly $3900, local welder wanted $1500 to rebuild bottom without teeth. Called another bucket builder, they wanted $1500 to 1700. Called another, attachment builder, they said $700. I was looking mine over today, I would like to attempt to straighten mine and if it does not work, then have my bottom rebuilt.
