Tractormech
- Joined
- Aug 18, 2020
- Messages
- 28
Hello all -I'm working on a 334G serial 234513479. It smothers and stalls out. All filters have been replaced and I even added a temporary fuel tank to eliminate trash in the tank clogging the supply line.The fuel solenoid has been replaced as well. The problem isn't constant. It may run 2 hours with no issues the will quit running 5 times in a row in 5 minutes. There's no rhyme to it's occurrence. My manual shows a computer of sorts that controls power to the solenoid but the dealer says it doesn't have one so someone's wrong. I will bypass the solenoid to eliminate that possibility as well. I think the hydraulics are going to full power and stalling the motor. Is there a stroke valve that controls pump output? And does a computer can the stroke valve?Any experience or advice is greatly appreciated. Thanks!
