Bobcat Tilt /Lift now every morning when I start the machine up (Codes 32-40 or 32-35) – This ONLY happens when I use both the lift and tilt at the same time. If I just use one at a time no problem – the second I use them both I have either one of the codes, mostly the 32-40 Lift not in Natural. I don’t believe it’s electrical – I have chased all of that down already / I believe this is a Hydraulic issue with the BICS. This is a 2002 – 863G with AHC – metal box (W/Push button float joysticks, and bucket positioning - NO foot pedals) – I’ve recently found out If I shut off the machine and leave the BOOM all the way up and walk away for about 45min to 1hr, everything works perfect for the rest of the day – I cannot make it fail. This seems like something must be stuck/blocked in the BICS hydraulics and gets released once the pressure builds up or the pressure is released. I’m wondering if it could be a check valve, lift or lock valves or the BICS Valve itself I bench tested it the BICS Valve it seem to move when I applied 12v to the Solenoid - I don’t know hydraulics that well – I wanted to get help from the experts before I chase my tail any further. I’ve been chasing this for 2 years now thinking it was electrical – I think I have ruled that out. Everything works perfect now except for this issue with the Lift / Tilt as I stated above when I leave the BOOM up and shut the machine off and walk away for about 1hr. everything works perfect for the rest of the day… This only happens when I put the machine away for the night with the BOOM down the next day I have the issue all over again. I did find one problem when I removed the Main relief valve, Per the drawings I reviewed there was 1 missing o ’ring and back up ring (Replaced those just last week). What I have done over the past 2 years. Replaced the main controller – Voltages were not up to spec. at first – When I first bought it. Checked all electrical connections all up to spec’s – Voltage, and Ohms Replaced every connector pin in all of the wire harnesses – I know I was bored and it’s not difficult with the right tools. Replaced Solenoid, Bench tested the AUX valves both – Seem to be fine. (AUX stems seem to be fine bench tested and they work fine). Replaced Actuators both the Lift and Tilt. Replaced Tilt/Lift spool springs and seals. Battery reads fine – when I put a load on it, it’s at 960cc and State of Health is about 90% Alternator puts out between 13.6 to 14.2volts when running – I have the Deluxe Panels that reads the voltage also checked with Voltage meter. Any help would be greatly appreciated.
