Bobcat Skidsteer Forums
313 poor steering control
Reply to thread
Message
<blockquote data-quote="skidsteer.ca" data-source="post: 31772" data-attributes="member: 307"><p>I believe the electric clutch on these is used to shift the drive belts from a hi to low ratio. Then the machine has the internal wet disc clutches to apply forward and reverse to the wheels on either side.</p><p>Could you post a picture or two of the electric cluch setup?</p><p>I'm pretty sure the internal wet disc cluches will be dealer only items. There is one for forward and reverse on each side of the machine.</p><p>The electric clutch is basically your shifter from hi to low range.</p><p>Ken</p></blockquote><p></p>
[QUOTE="skidsteer.ca, post: 31772, member: 307"] I believe the electric clutch on these is used to shift the drive belts from a hi to low ratio. Then the machine has the internal wet disc clutches to apply forward and reverse to the wheels on either side. Could you post a picture or two of the electric cluch setup? I'm pretty sure the internal wet disc cluches will be dealer only items. There is one for forward and reverse on each side of the machine. The electric clutch is basically your shifter from hi to low range. Ken [/QUOTE]
Verification
Post reply
