3-line attachments to a 2-line machine.
mikweb
I have a 2002 773G that has only 2 hydraulic connections and 1 power connector. I would like to run some 3-line attachments but do not know what is needed for the 3rd hydraulic line. Any help would be appreciated.
Can you just not attach the small third hose from the attachment and the attachment will work? I am new to this and would appreciate some insight on how to plumb the needed 3rd line to the machine.
The third line is meant to be a case drain for attachments. The drain just goes to tank so I don't see a problem with plumbing in a third line to handle that low pressure oil. There is a danger of blowing out motor shaft seals on and auger or other attachments without a place for that oil to go.
Because it is low pressure it may be easy to pipe a new line back to your hydrualic oil tank. Then you know you are safe.
if it was as simple as a Tee in the return line the attachment manufacturer would have done it, the return line when the attachment is running will have more pressure than a case drain line, I would not Tee it in but its not my machine
better run a line to the hydraulic tank
