Other Brand Skidsteer Forums
Caterpillar Skidsteer Forum
247b needs help
Reply to thread
Message
<blockquote data-quote="bobcat_ron" data-source="post: 28230" data-attributes="member: 1066"><p>If you have an A/C run of the engine with a belt, then the A/C pump is shot, that's the problem you are having with the slow down, even if the cold air isn't as cold as it used to be is a warning sign, if it was hydraulic causing the issue, it would have done something really bad a long time ago.</p><p>The current B series have an electric motor that runs the whole A/C show, no more belts.</p></blockquote><p></p>
[QUOTE="bobcat_ron, post: 28230, member: 1066"] If you have an A/C run of the engine with a belt, then the A/C pump is shot, that's the problem you are having with the slow down, even if the cold air isn't as cold as it used to be is a warning sign, if it was hydraulic causing the issue, it would have done something really bad a long time ago. The current B series have an electric motor that runs the whole A/C show, no more belts. [/QUOTE]
Verification
Post reply
247b needs help
