2050 Right side will not move
Jbohannon
I have just rebuilt or replaced both drive motors. The left was rebuilt I bought a new one for right. The right was not turning so I replaced it and mechanic said the other needed repair. So I did. When I got it back both worked now the right has slowly stopped working again. I bought the motor not the mechanic. Is there anything else that could cause the motor not to drive. It seems like it will bog down but not turn. I have heard there is some kind of drain back valve that can get stopped up. Any ideas. Thanks Joe Bohannon
It is possible something is binding up in the chain case....
One way to tell is to pull the motor off, disengage the brake and see if you can get a wheel to turn freely. Both should turn at the same speed and direction.
Could be the parking brake on that side
