Other Brand Skidsteer Forums
Mustang Skidsteer Forum
2044 foot controls
Reply to thread
Message
<blockquote data-quote="wirenut" data-source="post: 43821" data-attributes="member: 5619"><p>hey, rookie, thanks.......I got them off with an impact gun.......you're right....they put locktite on the bolts.......anti seize is a good idea.....will do that next time I take off......I took the cover off and cleaned all out under it......was ridiculous.......you are right about light coat of oil being a magnet.....bad idea.......I found 2 nuts, a cap screw and washer (looked almost new) piece of insulation and some type of wire connector with a wire on the end of it down under everything.........don't know where that cap screw came from</p></blockquote><p></p>
[QUOTE="wirenut, post: 43821, member: 5619"] hey, rookie, thanks.......I got them off with an impact gun.......you're right....they put locktite on the bolts.......anti seize is a good idea.....will do that next time I take off......I took the cover off and cleaned all out under it......was ridiculous.......you are right about light coat of oil being a magnet.....bad idea.......I found 2 nuts, a cap screw and washer (looked almost new) piece of insulation and some type of wire connector with a wire on the end of it down under everything.........don't know where that cap screw came from [/QUOTE]
Verification
Post reply
2044 foot controls
