2020 bobcat t770 injector code
jessemead
Got a 3000 hour machine with an injector code that pops up every couple machine hours. It is E000651-31, injector #1 fault.
Should I be worried? Just roll with it? What are options for repair?
I would look at fixing it as if it goes bad completely it will put you in a limp mode, I have a different machine, but I had a problem with the wiring harness to the injectors ( open circuit to one injector) and it was a pain to find as it would come and go into limp mode. but your just might be the injector.
reman. injectors should be set to the same specs. as new injectors, should be able to just put them in. and purge air out of fuel lines.
