2018 Gehl RT175 drive code errors (pump left/right sensor neutral drift fault)
DeepSouth
I was attempting to climb a fairly steep bank with my skid-steer. As I started up the slope, the engine just shut off, and has not restarted. there are two drive codes now showing...code numbers 1 and 2. #1 Pump Right sensor neutral drift fault and #2 Pump Left sensor neutral drift fault. The engine will crank, but not start. I have checked all fuses and connections. Diesel is full. Any ideas how to correct this?
CentecEquip
Did you ever figure out the issue i have the same machine with the same problem. any info would be great. only differences is my machine is starting. just wont release parking brake. no control functions work.
crouton95
We ended up swapping the sensor connectors on top of the pump got the machine to move then swapped them back! Just be careful because the machine will not stop once you hit forward or reverse you will have to kill the machine by turning off the key.
