2018 Bobcat T650 Idle Only
Log_Head
Just purchased a "non running" bobcat pretty cheap from an auction. It will idle but it's rough. Not throwing any codes that I see yet but I do have the video below. Was told it has fuel system issues which I know is common with these. Hoping it’s just a pinched/plugged line, fuel filter or maybe plugged injectors. Machine has 3700 hours on it. Won’t go above an idle.
YouTube video of it running.
What do you all think is wrong with it?
Thanks
Just purchased a "non running" bobcat pretty cheap from an auction. It will idle but it's rough. Not throwing any codes that I see yet but I do have the video below. Was told it has fuel system issues which I know is common with these. Hoping it's just a pinched/plugged line, fuel filter or maybe plugged injectors. Machine has 3700 hours on it. Won't go above an idle.
Thanks
Sorry, you need an entire fuel System, it is not even running on all cylinders.
Performed a static injector test. Found injector 1 and 3 had a leak bypassing to the return.. Replaced them and it runs fine now. I used the cheap Amazon injectors. Will see if they hold up.
