2017 T550 battery drain
Leutik31
Hear a buzzing noise around the alternator when machine is off. Drains the battery doesn’t happen all the time.
i would get a another person to pull fuses and relays one at a time while you listen for the buzz to go away, then you will know what circuit is involved, that should make finding it easier.
disconect the negative terminal put a test light on it from cabke to battery and pull fuses till the light shuts off ignition off
