Stumped! I have a 2015 CAT279D I charged the battery overnight on a slow AGM trickle charger as i have done many times before but this time and next morning i had no screen display, no beep, no fuel pump. So i have tested the fuse panel and no voltage. I checked the main fuses-good I checked power to ignition switch-no power to BAT terminal. I checked the Large studs behind the cab and had 12v. I checked the smaller studs below the 6 mega fuses. They were readings of 12v -0v 12v-0v 12v -0v....strange. I fused jumped the six studs together...now i had power to the fuse panel...still no power to the BAT terminal on the ignition switch. I removed the jumpers and tried to jumper the ignition switch BAT terminal...no change. I am about to blow a fuse myself! Any ideas? Help!
