So, in case anyone else has this issue, and doesn't know.. The boom pedal is locked out by the small round solenoid all the way at the bottom of the control valve body, under the left (boom) control pedal. (Mine has blue wires on a 2013 model)
I lucked out. My machine decided to start working again, (about a week after the boom got stuck in the air, and I got to climb out the rear window again... My hydraulic release plunger has never worked, so lowering things that way is not an option. Yet.) . So, rather than chase hard-to-get resistance values off solenoids way down inside there, I unplugged solenoids til I re-created the boom pedal-only lockout. Bingo.
I pulled the boom pedal to access the control valve. Then I had to bend the arm that supports the hydraulic release cable (which I found is also frozen solid, and a battle for another day) out of the way to access it with vise-grips, I didn't have a one-inch wrench short enough to fit in there. As expected, the solenoid wasn't in there very tight, and it came free pretty easy this way. If you could believe it, my 1" crow's foot was the ONLY one not in it's spot. Huh.
Also, I'm not sure how long it will last, but I went with the cheapest, Chinese-est solenoid I could find on Ebay. John Deere wanted around $600 for a 340719, I paid $29 shipped. The knockoff is a bit smaller in diameter, but fit and works just as the factory one did. Now that I know it worked, I may order a couple more just to have them hanging around. I expected the plugs to be cheap-feeling junk, but they weren't too bad. Granted, I did this swap at 65 degrees, and not 16 below zero.
While I was at it, I changed the fuel filters, and checked the pickup tube, to see where the de-rate/ low fuel pressure issue was coming from. Guessing the pickup tube is getting blocked with gravel, so the plan is to run the machine a bit lower on fuel, then drain and clean the tank. It looks pretty black down in there. It's always something. Either way, I'm up and running again, and able to go above 1600 rpms for the first time in a while. So that's how much power I was missing.
