2012 N.H. T4.75 *No Movement*
bfusco84
Neither Tractor nor bucket move. Starts fine. Here's the scenario: removing felled tree for firewood I backed up over a high stump (stupid-I didnt see it) and got stuck. After jacking up and getting under with chainsaw I was then able to rock tractor out and off stump. Then noticed fluid pouring out under right side (Hydro fluid) from rubber coupler that became damaged and snapped ring clamp off ALSO pinching the same line towards the back...Although NOT completely pinched*. I was able to repair and reclamp line. Filled up with (J20A) Fluid-fired it up and starts but NOTHING now moves...I think 303 fluid was in it before..but should that matter? Also it us about freezing temp outside...but could the kink make no movement or is there another issue?
my first guess is air in the pump and the cold is making it worse by making the oil thick, see if you can purge the air out from somewhere.
That's what I originally thought...Didnt see much...Btw-Uncles tractor-not mine. Sincerely hope it's just the cold....
