BlackMntDemo
- Joined
- Aug 18, 2020
- Messages
- 4
Hey guys, new to this forum and looking forward to being a member! I just bought a 2012 Cat 242b3 with 710 hrs. Unfortunately it didn't come with the manual. I.D #*CAT0242BPSRS02222* I've used it a few hours already and it runs great, but it has a hydraulic leak. I lifted the cab and the leak seems to be coming from the big plastic hex fitting coming out of the bottom of the hydraulic reservoir behind the seat. This fitting has a larger diameter rubber hose on it, maybe 3" or so. The steady drip is coming from the base of this big hex fitting where it mates to the reservoir. I am HOPING there is an o-ring that has gone bad. What's the best way to attack this? My thought was to just drain the hydro fluid and pull that fitting apart, see if I can figure out why its leaking. However, the belly of the machine is such a mess from fluid and dirt that I can't even figure out where to drain the fluid from. Any tips? Once I fix the leak, Is there a way to safely clean the inside of the machine? I can't stand how filthy it is in there. its driving me crazy already. thanks in advance guys!
