Bobcat Skidsteer Forums
2007 S250 won't start
Reply to thread
Message
<blockquote data-quote="tyan707" data-source="post: 20769" data-attributes="member: 2141"><p>Problem solved, it was a faulty starter. The starter was shortening out inside causing the wire to heat and not having the power to turn the flywheel. Replaced the starter and now it starts easily and working good. Thanks you all.</p></blockquote><p></p>
[QUOTE="tyan707, post: 20769, member: 2141"] Problem solved, it was a faulty starter. The starter was shortening out inside causing the wire to heat and not having the power to turn the flywheel. Replaced the starter and now it starts easily and working good. Thanks you all. [/QUOTE]
Verification
Post reply
