Bobcat Skidsteer Forums
2007 S250 18-06 error code
Reply to thread
Message
<blockquote data-quote="BlackWhiteandOrange" data-source="post: 20797" data-attributes="member: 2188"><p>This code is for the lift and tilt spool locks on the control valve. I am guessing that you have a bad coil or a short in the harness. Most likely once the coil heats up, it is shorting out. If you get the code to come up again disconnect one of the coils and cycle the key. If the code goes away then that is the one that is bad.</p></blockquote><p></p>
[QUOTE="BlackWhiteandOrange, post: 20797, member: 2188"] This code is for the lift and tilt spool locks on the control valve. I am guessing that you have a bad coil or a short in the harness. Most likely once the coil heats up, it is shorting out. If you get the code to come up again disconnect one of the coils and cycle the key. If the code goes away then that is the one that is bad. [/QUOTE]
Verification
Post reply
