2007 Case 410 fuel bleed
aa21830
Posted a question a couple weeks ago about bleeding air from the fuel lines. On the 410, does not appear to be a hand pump or anything similar. Took a pic of the distributor pump...is the allen-head bolt a bleed screw? http://john-stichnoth.com/images/InjectorPump2.jpg
Really don't know, it's worth a go at loosening it up and seeing what's underneath it. Normally the bleed screw is on the fuel line that goes to the pump, but different models have different setups.
A
aa21830
Guess that was a bleed screw...loosened it up, cranked over the engine a couple of times, tightened it and she fired up.
Glad you found it, and it worked. They don't make it easy to spot do they?
