2006 A300 lift and tilt not working
trevorsc
Lost all function on the right joystick. Operator was loading a dump truck. Lost tilt function was able to bring the boom down. Then Lost lift and tilt all together. When the seat bar is lowered and you press the press to operate button the seat bar light and traction light illuminate but the lift and tilt light does not turn on. I have no codes in the hour meter or on the right hand display. Checked fuses and relays. Disconnected battery. Checked lift bar, seat belt and window switch. Disconnected the bics solenoid and tested ohms its at 9. Also pressed the press to operate button and received a code with it disconnected. So it seems the circuit is working. Joysticks were replaced last year to the updated style.
I'm running out of ideas and my local bobcat dealer is 2 weeks out.
