2006 332 getting hot problem
Radicalrandy67
Have the above tractor, it works great for about 40 minutes then gets hot. Does this machine have a hydraulic temp shut off. The engine does not seem to get hot but the temp hits 225 and it starts beeping. You have to idle for about 5 -10 minutes then you can work for about 10 minutes repeat. It has two temp gauges is one for hydraulics? Does not spit out water and have had radiator check and new water pump installed.
