Bobcat Skidsteer Forums
2006 262B no hydraulics
Reply to thread
Message
<blockquote data-quote="Bertdownton " data-source="post: 99241" data-attributes="member: 11550"><p>Looks like I finally had chance to work on this machine last week, after doing multiple tests and pressure tests on hydraulics it was determined to be a mechanical fault, ended up removing engine and replacing the the nylon drive gear on the flywheel, it had stripped causing the main hydrostatic pump not to turn.</p></blockquote><p></p>
[QUOTE="Bertdownton , post: 99241, member: 11550"] Looks like I finally had chance to work on this machine last week, after doing multiple tests and pressure tests on hydraulics it was determined to be a mechanical fault, ended up removing engine and replacing the the nylon drive gear on the flywheel, it had stripped causing the main hydrostatic pump not to turn. [/QUOTE]
Verification
Post reply
