2005 s220 blue/white smoke
crowbar
Hello everyone!
I have a 2005 s220 that is smoking blue/white looking smoke. The oil level is low so I’m pressure it’s burning it. The valve cover leaked but it’s not a lot. I wasn’t told it could be a bad turbo or valve stem seals and bad piston rings.
Would the smoking be cause from the turbo? There is some shaft play but you really have to put effort on moving it.
Or would the smoking be from piston rings and valve stem seals.
I’m not sure where to start. Thanks for the help and advice!
Maybe a bad injector? Try loosening the steel line at the injector while engine is running, one cyl at a time to see if one doesn't make a difference. Helps to break them all loose and just lightly tighten them before starting the engine
