I think that the poppets are fine, they do not seem to show any abnormal wear. The only thing on the poppets that concerned me was the poppet for the lift function (located in the end of the BICS check valve assembly) is somewhat loose fitting in its sleeve compared to the other poppets. It is a slightly different design than the other poppets and it does not look worn, so I am guessing that this is normal. The main concern I have with wear is on the ball/seat check inside of the BICS/Lift check valve assembly. I attempted to post a picture with no success. I cannot get the HTML editor to work. I will try more later. There is an album in the media section called "Combination BICS and Lift Function Check Valve Assembly" which contains two pictures of the BICS/Lift check valve that I am working with. The item showing wear is item #2 in the second picture. It has a defined groove worn around the ball surface that I can snag a fingernail on. I would venture to say that if that piece is meant to seal fluid completely off that it is not working properly. I've done a lot of carb work, and if a needle and seat looked like this, it would not hold gas back. I am still working on getting o-rings to replace and I hope that works. I priced out the entire BICS/Lift check through B-Cat.....$415.59!!!!!! Yikes. Also, I checked the leak down. They do leak down very slowly. Probably about 1/8" per hour measuring on the cylinder.
