2004 S300 shuts down
Stick-man
I have a 2004 S300 with the Gold Package (keyless panel). It will just completely shut down for no reason. Then when I press the yellow Run/Enter button, the panels will cycle but then immediately shut off, so you can't put in the unlock code. A while back someone mentioned some solenoid on or near the main valve??? Any ideas?
bobkat843
sounds like one of the sending units censers are acting up . I would start by Try unplugging the oil pressure censer
7LBSSMALLIE
i would start at batt (clean connections load check etc) than pink white wire that feeds panels. to ensure it will carry amps not just voltage, than onto boost. as to wether its incorpated in controller or is early model add on located behind rh headlight
