2004 753G Bobcat Error codes
triumphtek
Have the unit listed above. Went to start the other day after sitting on my property for a couple days and turned the key, display said REPLY and flashed (in the background) the countdown for the glow plugs. When you turn the key lights come on as usual. It is detecting the seat bar switch, battery is good, when you turn the key though you get nothing?? Does anyone know if what this code on the display means? Thanks!
“REPLY” means one or both instrument panels are not communicating with the controller.
Could be a dirty connection or rodents chewed on some wires while it was sitting.
My bad on the year. Its a 1999, was thinking about my other Kubota. Will get the multimeter out today and see what I can find. Keep it indoors most of the time.Its starting to get cold here in WI. Had it on my land for a job for about a week and I will bet your right, MICE! BTW, know of anyway to keep them off your equipment, that works well?? Thanks!
That code normally means bad controller.
