DrByte
- Joined
- Oct 23, 2024
- Messages
- 8
Greetings! Skid started overheating in less than 10 mins only handing light loads. Coolant fine, water pump fine, oil backing up the dipstick and out. relatively new oil is black. kubota d722-e engine. About to pull valve cover and clean the crankcase ventilation (housing on this one is molded into the valve cover). no time to order and wait for new valve cover gasket. I intend to use Ford hi-temp RTV to reseal as a stop gap while waiting for a new gasket. Also intend to change oil and replace the dipstick as the fit is loose, possibly worn? The skid is a daily driver on the farm and essential, so any advice on the best way to approach this would be appreciated.
Thanks, you guys are the best!
