Bobcat Skidsteer Forums
2001 773G ACS - No lift/tilt
Reply to thread
Message
<blockquote data-quote="7LBSSMALLIE" data-source="post: 56488" data-attributes="member: 6879"><p>first and fore most is the seat bar light ,it needs to turn on as well as off .respectivley sa raised and lowered. super early 773 (i may be mistaken) incorpated a seat switch, if it has it switch needs made contact prior to seat bar coming down. or it tricks the sys out. the seat switch was a major pain due to stuff under seat (right rear) not allowing contact. easy fix if this youre sys is called a push kit. takes out seat switch and you have to push a button like in the old days, good luck and, please dont bypass any safety stuff. youll be dead and bobcat gets a bad rep, and us techs will be sad,</p></blockquote><p></p>
[QUOTE="7LBSSMALLIE, post: 56488, member: 6879"] first and fore most is the seat bar light ,it needs to turn on as well as off .respectivley sa raised and lowered. super early 773 (i may be mistaken) incorpated a seat switch, if it has it switch needs made contact prior to seat bar coming down. or it tricks the sys out. the seat switch was a major pain due to stuff under seat (right rear) not allowing contact. easy fix if this youre sys is called a push kit. takes out seat switch and you have to push a button like in the old days, good luck and, please dont bypass any safety stuff. youll be dead and bobcat gets a bad rep, and us techs will be sad, [/QUOTE]
Verification
Post reply
