would napa brand hydraulic oil R+O, AW32, etc. work?Just plain 'ol engine oil. Nothing special.
Members have even used old hydraulic/hydrostatic oil. If you are looking at replacing the oil in your drive/hydraulic system, you can pump it out into a drum and replace what you pumped out and put the old stuff (if it's not contaminated with water or metal) into the chain case. I have done this before, saves dumping oil that is still just fine for the chains/sprockets and bearings.
Don't see why not.would napa brand hydraulic oil R+O, AW32, etc. work?
With these 'leaky' old machines I've got......I've used the cheapest hydro oil NAPA has.Don't see why not.
thanks for the adviseWith these 'leaky' old machines I've got......I've used the cheapest hydro oil NAPA has.
