I have run a jumper wire from the positive post to the battery to the fuel solenoid and it starts, but the tilt foot pedal is locked in position. They lift pedal works fine. I have checked the fuses in the cap. I have checked the fuses in the firewall area. All are OK. I changed relay on the firewall still will not start. It starts for a second with the original wire hooked to the solenoid, and there is no voltage at that wire and it will run if I keep the key in the crank position as soon as I let off of the key it stops I removed the dash panel. Everything looks good there there’s no cut wires no mice evidence same for the ignition switch area very clean in there. What other place should I look for? Is why the solenoid is not getting any voltage. And why is the right pedal locked? L, it will crank with a seatbelt unfastened. When I run the jumper wire from the positive Post of the battery to the fuel solenoid it starts right up, but again the right pedal does not work and a seatbelt is unfastened. Any help appreciated
