1996 Bobcat 751 Injection pump
Grass
Looking for help locating an Injection pump for a 96 bobcat 751
Engine Peugeot XUD9
Injection pump is a Lucas
Best I can tell part numbers are
Type- PCM12
DPC-R8444B912B
Can you get yours repaired? these are quite hard to get now, and are expensive :(
Was hoping to buy one. I may send it off on Tuesday if I have know luck locating one
Hi I'm new to this forum and I have the same exact pump and engine I'm having issues on getting it to prime and was looking for the proper pump timing procedure and bleeding process if anyone can help?
I would like to know this too. I just bought a 751 that the dealer got to run by "blowing air into the injection pump with a fitting" that is what I was told at least.
I was also told it could be the fuel line fell off in the tank. I don't think that is the problem.
1. I squeezed the fuel bulb and it was hard.
2. I turned it over it did not fire.
3. I checked and I am getting 12 vdc to the fuel cut off solenoid.
4. I pulled the fuel cut off solenoid and it it pulled with 12vdc applied
5. I cracked all injector lines at the pump. Nothing
6. I moved all 4 lines at the pump off to the side. And not a drop came out when cranking over.
