1994 940 oil cooler
mustang has it available, old # is 170-33424, new # should be #50294877, they are expensive, could yours be repaired?
Not sure I think it's blocked,after working on site for 1 hour buzzer went off and light,let sit for 1/2 hr nothing went off again,fins are clear but rusty,top hose hot bottom cold
which light was illuminated, could be an engine temp light, is it moving a lot of air thru the radiator,
the light all the way on right sitting in cockpit,yes plenty air moving thru rad,all fins are clear
ok, if u feel its plugged id remove hoses & use compressed air to see if its actually plugged, i have also seen faulty temp senders
