Ok call me stupid. Bought a loader from a family member on "his word" Told me it ran great had a very small hydraulic leak. I loaded it up and brought it home. First thing I did was to pull a full PM. found the hydraulics to be about a gallon low. Lifted up the cab and observed the right motor well to have lots of hydraulic oil, left side was dry Filled up all fluids and went to work. Noticed quickly that the right hydraulic motor, as I sit on the unit was overrunning the left. Also noticed that the left motor was very smooth all the way thru the range but the right motor had a noticeable jerk at about the half way point. All the loader hydraulics operate great. Plenty of lifting power. After a 30min run I lifted up the cab and noticed more oil in the right drive motor area. I took off the right motor cover and had my son operate the unit. I notice that there was oil coming out of the two hex caps on the face of the motor, assume this is a pressure relieve valve. I took the caps off and checked it all out. No issues there with the plunger, springs or caps. I replaced the O-rings, restarted the unit and noticed that about the time the right motor jerks at half speed oil squirts out. Everything sounds good. No noise from the hydraulic system. Need some help
