1986 L555 won't start.
x2jones
Last Saturday, I moved my L555 by trailer. It shifted during transit and put additional tension on a chain I used to tie it down. I started it, moved the skid steer forward about a foot on the trailer, then cut it off to remove the chains. After doing this, the skid steer won't start. I try to crank it and I hear a clicking noise to the right rear of the cabin. Further, it seems like it's not in neutral and stuck in gear. What could've happened with me moving it on the trailer? Thanks for any input.
If you hear a continuous rapid clicking, then the battery is low on charge or you have a bad battery connection. Either way you are low on voltage. If it is only one click then the relay in the engine compartment on the right side may be bad or possibly the starter.
