As I don't have the starter or flywheel off the original configuration, is there a way to determine the pump shaft rotation direction? The specs I have found on the VH4D says it spins CCW. Bobcat drove the pump from the front the flywheel side (front) to achieve clockwise direction? At least that is the way mine is setup. Is there a way to determine the proper rotation direction of the Vickers hydraulics? Sources to check? I want to order a repower kit using the Kohler vtwin but they want a rotation direction.
