1845c
cuttman
My high flow switch is missing, can I replace it with a regular toggle switch or do I have to replace it with the more expensive switch.
Are you sure it has high flow? not all machines have it, saves buying a switch and finding it's not even fitted.
Yes I am sure. Have two sets of hydraulic lines. 1 on each side of skidsteer. High flow on right, also have wires on my left control arm where the switch goes.
If it's just an on/off switch i see no problem using an off the shelf switch. Some of the newer machines use vairable aux hydraulics that use a special style switch that is a vairable resistor.
