Other Brand Skidsteer Forums
Case Skidsteer Forum
1845 smoking and fuel in the oil
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 58306" data-attributes="member: 82"><p>If it's getting into the oil too, i would suspect the injector pir lift pump is leaking.</p><p>An injector can cause white smoke, as can a burnt piston or ring. If you take the injectors out and look at the tips, see if any look wet or different to all the others.</p><p>Is it a turbo machine at all? a bad turbo can give a lot of smoke too.</p></blockquote><p></p>
[QUOTE="Tazza, post: 58306, member: 82"] If it's getting into the oil too, i would suspect the injector pir lift pump is leaking. An injector can cause white smoke, as can a burnt piston or ring. If you take the injectors out and look at the tips, see if any look wet or different to all the others. Is it a turbo machine at all? a bad turbo can give a lot of smoke too. [/QUOTE]
Verification
Post reply
