1845 Case filter light
BIGTOYZ II
The filter light on my Case 1845 located on the right side of the ROPS has recently come on and stays on. I have replaced the hyd filters located under the seat and above the motor but the light is still on. Am I missing a third filter or is there something more I need to do to turn the light back off? This is for hydraulica nd not an air or diesel filter? Thank you for any info.
locate the sensor that is activated ,check around the area the wires connect to it and look to see if it is leaking oil. usally that is a sign it has gone bad. It can still be bad if it is not leaking still though , but if it is that is a quick sign of a problem like you describe.
