I have a Bobcat 731 that I have owned for several years. Recently it started leaking from the tilt cylinder. The leak seemed to be coming from the cylinder's lower hydraulic fitting. I replaced the o-ring and it got significantly less, but then I used it for a larger job and it started leaking seriously again. It only seems to leak when the machine has been used for long enough to get the oil hot. I'm thinking it may be leaking from the seal around the gland nut which would present as coming from the fitting since they are right next to each other and the fitting is lowest. I got a re-seal kit and removed the cylinder from the machine. I could not figure out how to get it apart. The gland nut just rotates, it does not seem to be threaded. The lower hydraulic port is in the gland nut. There is a slot about 3/16" wide and 1 1/4" long in the cylinder body approximately 3/8" below the gland nut. It seems to have two ends of a ring in there, but no way to get it out. The cylinder is original Bobcat equipment made by Cessna. I took it to The Bobcat dealer and they can't figure out how to get it apart either.
I'm hoping someone here knows how to get it apart. If not, it's looking like I'll need to replace the cylinder.
