Thanks, I'm looking at buying used ones, so interested in which ones might be too small or underpowered.. JamesJust about any modern Skidsteer will have enough power. Some of the early machines were a little underpowered, but would still do the job, only slower as you'd have to ease back on the sticks. I don't believe the big machines would be too big for snow work, the only issue you may have is access, but i'd suspect its mostly for parking lots and driveways? where access isn't a problem. You will have more weight and more power with a larger machine to allow you to do more in less time.
I have never worked with snow, 'm sure others will pop their noses in and give you their thoughts too.
I had a mid 70's M-700 that did a good job with the snow in Minnesota. If it was wet and heavy, I just picked up smaller loads as the heavier ones would cause the bobcat to tip forward. I have a mid 80's 843 that does a GREAT job of handling the Ohio snow - not that we have much at all here. the few times I've had to move over 6" of depth, the loader was more than capable.Thanks, I'm looking at buying used ones, so interested in which ones might be too small or underpowered.. James
